Not enough hot water--need help!
124»
  • HomerJSmith
    HomerJSmith Member Posts: 2,816
    edited February 2018
    Kunisk, how about some accurate temperature measurements on the boiler input and output of the tank. Take a measurement when you start to draw hot water and the boiler commences to fire. Take another reading when the tank begins to run out of hot water.
    Mark Eatherton
  • HomerJSmith
    Here's a thought, maybe there's a manufacturing defect in the tank and there isn't a dip tube in it and it isn't stratified.
  • SeymourCates
    SeymourCates Member Posts: 162
    @HomerJSmith
    Well done.
  • Grallert
    Grallert Member Posts: 1,187
    Assuming that 6:00 on Homers diagram is the front of the tank It looks like OP's tank is piped wrong. But then it wouldn't work at all would it?
