Can I use Taco 400-4 1/8-Inch-NPT Float Air Hy-Vent on the return on a steam system
acl10
acl10 Member Posts: 349
Can I use Taco 400-4 1/8-Inch-NPT Float Air Hy-Vent on top the return on a steam system. When I put steam vent like Gorton on the return water came out. I changed it to this taco and no water comes out. When it comes on air comes out and then when the return fills with water its shuts.
  • Ironman
    Ironman Member Posts: 7,717
    You don't vent the wet return of a steam system. The vent belongs at the end of the steam main or on the dry return.
    Bob Boan
  • acl10
    I did both I see that the wet return goes faster
  • Fred
    Fred Member Posts: 8,542
    AS was said, you don't vent a wet return.
