Old
Harvey Ramer
Member Posts: 2,266
That company was bought out by Rheem, sometime in the late 1950s or early 1960s.All Steamed Up, Inc.
Consulting1 -
Nifty! 25 years ago when my Big Brother Bart moved in to his home, I told him to start putting aside some $ for his "old" Hart & Crouse Gas hw
Boiler with powerpile that around 28-30 yrs old
Besides one powerpile generator, and a repipe to accommodate a radiant zone 15 years ago, the boiler has needed NOTHING! He gleefully reminds me every heating season.
Mad Dog1 -
It's not gravity. It's 5 zone pumped.
@ratio Sorry. You'll have to find your own.
@Steamhead Thanks for the history. I was unaware that Richmond boilers existed. Is it the same company that made the Richmond cast iron Rads?
@Mad Dog He wants to replace this one. I'm not so sure that he should. Maybe just clean the system water side to bring the efficiency up a few points.
@Ironman That looks like more pipe than boiler! 2 loop gravity system?0 -
Sometimes people want to reclaim a little floor space in the basement.
What changes would make the boiler more efficient by a few points-pipe insulation, burner downfiring, etc?—NBC0 -
It was. Now it looks like this:Harvey Ramer said:It's not gravity. It's 5 zone pumped.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
^ Beautiful job Bob! I'm saving your photos for future reference.
I see you piped the UFT P/S... how is that working out?
Any problems with air removal?0 -
Works great. No air problems; system has CI rad's, so any air that makes it to them has to be manually bled at the rad.Bob Boan
Cleaning up the system on the water side increases system efficiency by allowing the heat from the flame to reach the space to be heated, in less time. It does not necessarily affect combustion efficiency.0 -
^ great!
I can personally testify that the UFT loves cast iron, I'm sure the HO is thrilled with the new system. They probably have hours long burn times with zero cycling.
I especially like your hydraulic separation device, inexpensive, effective and simple... will probably last forever too. Kudos on the design!-1 -
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
I like anything that ends with "omat."Retired and loving it.0
I googled "omat". Now I'm very confused.0 -
As in Heatomat. The old beauty In the pic.Retired and loving it.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
