More school lack of maintenance
DanHolohan
Member, Moderator, Administrator Posts: 16,537
You can't fix stupid.All Steamed Up, Inc.
Consulting0 -
Not for nothing, but this is nothing new.... public school infrastructure has been neglected for decades at this point. It's just finally reached critical mass where the "I told you so's" are now happening and systems are actually failing and beyond repair.
Funny how the superintendents can make $400,000+ and still have all these problems. You would expect exceptional management at $400,000 salary. There is literally no accountability in public education any more.
https://patch.com/new-york/portwashington/long-island-school-superintendents-salaries-ranked-highest-lowest0 -
I suppose boiler chemicals were too expensive. Or it took too much time to make sure it was done correctly....0
idiots. Not afraid to publish their stupidity0
Maybe the chemicals were part of the problem!
I don’t believe the popcorn popping on the floor.--NBC0 -
I’m with you, NBC.Retired and loving it.0
I was a facilities engineer for a medium sized community college. The maintenance budget was barely even 1% of replacement cost and horrible mismanaged. We didn’t pay the hourly much but they had marginal skills.
When I got there I was the first person in 60 years that told them not to drain the hot water system in summer.
We had to draw a picture to explain to the 20 year veteran VP of Facilities what a chilled water coil was. We used pictures. I described it to my 7 year old daughter that evening and she understood it better. I left and they questioned whether I was really smart or totally full of BS and had no idea what I was doing. They also put up a new building that had so many engineering mistakes that the hvac was barely operable. But the A&E firm walked on water of course. It was pretty.
I argued with them for 10 minutes one time that of the building is super insulated and had LED lights, no sun and lower occupancy that you can’t remove humidity no matter how much you drop the airflow. I don’t know where these guys get degree from.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
