Shimming a radiator
Merry Christmas and sorry for the delayed response. Two radiators on the second floor have Hoffman 1a vents set to the lowest setting. There’s no water hammer but the vents do bubble a bit when the radiators become totally full of steam. They will also whistle like a boiling tea pot for a minute or two, also only after the radiator has totally filled with steam. The vents are new and do fill with some water, which I assumed might be the whistling issue, and that pitching might help.0
I agree wit @Fred if their working ok leave them alone. If the vens are spitting or you have gurgling the pitch them a little at a time. You can always shim them and try it add more if needed1
I’m just finding this 8 years late but I wanted to shim slightly due to rattling. The Vari Valve air vents do vent steam ok. It’s 50 years old is the radiator. All the others are 70 and sounds like the author’s setup. My concern is to have thin metal shims on carpet. I’m thinking it’s ok since the feet are in the carpet.
Quarters work very well, or slugs (remember those?) are cheaper!
thanks for the replies. I just realized I did not include part of my paranoia. It’s the heat I’m concerned over. Betting that doesn’t change any replies but to clarify my thought. The heat never burns to the level of combustion. I had seen dark marks in the base where the steam pipe runs up close to the flooring.
I'm not sure what you're saying, but if you're concerned about steam pipes causing combustion, don't be. ~212F is not hot enough by a long shot
ok thanks. The story is bigger than this actually to explain my worry. If the wood didn’t have a combustion issue then the legs/feet won’t for wall to wall carpeting. The larger part is I was told to get a reflective sheet to protect the paneling as it can dry out behind the radiator. This one is the only non covered one. So heat was brought to my attention as possible concerns. I’ve learned a lot trying to fix radiators and replace boilers in an aging house. Combustion is not my specialty in these kind of scenarios. I just take extra steps to avoid electrical and heating appliance impacts. Too many bad stories from house fires. Ok I rather side in paranoid. lol.
Drying out precious wood or other objects is a possible concern. I have to keep reminding my wife not to keep houseplants on the radiators.
I’ll attach a pic of the unit here just for show. The long level shows slight bubble to the left so maybe not required to shim just for small rattling. Btw the rattling stops after a while.
The level doesn't matter. It has to be wildly out of level to matter. It doesn't matter which way it pitches, within reason.
The bigger issue is that Vari-Valve vent, those things are a hazard.
I can't hear your rattling from here of course so I can't speak to its cause, but it's not the pitch of that radiator.
wow ok now I’m concerned because I used Vari Valves to replace terrible Maid O Mists. The system had gotten way better but mostly due to the green solution the pros used to help clear it or possibly seal issues.
I’m probably wandering into naivety but that solution seemed to act like the old honey oil additive for very old motor engines. I don’t trust most additives but that’s digressing.
The vari valves seem well made. I know there are better which usually gets reflected in price. Get what you pay for.
Are these hazards due to steam spitting? Or pressure? The worst issue while I had the maids was a huge water leak from the air vent because the involved radiator was just above the boiler. No problems since the change and the additive.
I will try to attach a small audio of the rattling. I was about 8-10 feet away the forum doesn’t allow the file extension but I think I can embed it in a doc etc
no soap unless I use the cloud link with an expiration on it read only as well. Do not want to break any forum rules either. I may ask the forum owners.0 -
If the Vari-Valves work well on your system, enjoy them. On some improperly piped systems they tend to spit water as they vent very quickly.
Some tend to fail. If you get a cold radiator, take off the velve and shake it. If it rattles, time to buy a new Vari-Valve!
There is some confusion in your response, but I will say that love or hate Maid O Mist, the vent was not the cause of water squirting out of it.
We are bolted onto the end of a multi-year old post for some reason, but you need help. Try the Find a Contractor page on this site.
- 123 Chimneys & Flues
