Converting Sears wall furnace
rmlynch25
Member Posts: 1
in Gas Heating
I have a natural gas Sears vented wall furnace model 867.730600 that came out of an old house. I'd like to convert it to use propane and use in my garage. What do I need to convert from natural gas to propane?
How many burners does it have? What is the input? Based on that I can tell you what size orifices you need. You will need a new orifice for the pilot. The gas valve needs to also be identified as to Make Model so a proper kit can be ordered to convert the regulator on the gas valve.0
Try to find out who was the original manufacturer and inquire there. Not all equipment is approved for changing from NG to LP. IMO0
Do you have the owner's manual? I couldn't find it on line... the ones I did find, however, suggest that specific models were LP, and others natural gas. You still might be able to convert, but you will need to change the burner orifices, the pilot assembly, the pilot orifice, and probably any gas valves or pressure regulators. Have you contacted Sears directly?Br. Jamie, osb
867 means it came from the Heil-Quaker side of things. If you can't get anywhere with Sears parts, good luck! A Hot Dawg isn't that expensive! And the ones at Menards are even less than a Dawg wholesale.
Can the Hot Dawg do LP?
I tried to do an older Heil furnace from NG to LP years ago and factory said no way for that particular model my customer had.0 -
ProCom Blue Flame are cheap0
And if you want to go really cheap and redneck, try Northern Tool or Tractor Supply... !Br. Jamie, osb
The Dawg can do LP.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
