Leak in Hot Water Pipes Concealed In Floor
Bobg7
Member Posts: 1
I have been told that there pipes related to our hot water heating system under a concrete floor that are leaking. Just wondering if there is any additive that can be used to plug the leaks in the same way that you can buy chemical additives to stop small leaks in auto coolant systems. Has anyone ever dealt with a problem like this by bypassing that section of the pipe and running a new pipe (or baseboard) around the perimeter of the room? Wouldn't that be easier and less expensive than ripping up the floor and replacing the pipe? Thank you -
That's stuff is not good for a boiler you want to keep using
Is it radiant slab heat?
You can run another pipe above but if it's radiant you will need to add some type of heat if you abandon it0 -
Don't put a stop leak type additive into the boiler. It will ruin it. I might add, don't put one into an automotive radiator, either; if the radiator is anywhere near sized to the engine (and most are, these days) you will overheat the engine someday on a heavy load.Br. Jamie, osb
No easy fixes here... sorry
Depending on the age of your system you could jackhammer up the floor or abandon.
If the pipes are only under the floor to get from point a to b and you can reconnect to them, then yes..abandon the pipes in place (foam them to seal off) and reroute somewhere else.. If as other's have said it's radiant, you could try and use a thermal camera to locate the leak and jack hammer that area in an attempt to repair it...0
What type of piping is in the floor? How old is it?Bob Boan
Abandon. More leaks may be coming. Ceiling radiant is nicer anyhow.0
- 123 Chimneys & Flues
