from rags to riches
newagedawn
newagedawn Member Posts: 586
latest install was fun knowing how much oil this customer will save!!!!!! from 1500 to estimated 500 WOW !!!!!! now thats savings
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
njtommy
    EBEBRATT-Ed Member Posts: 15,545
    Looks good!! Nice and neat. What did you replace??
    a couple of nitpicks
    blowdown pipe on indirect relief valve
    Id rather see a pc of 1/2" EMT or PVC conduit run from the indirect up to a floor joist as a sleeve for the low voltage going to the indirect instead of the tyraps on the cold water line
    newagedawn
  • Paul S_3
    Paul S_3 Member Posts: 1,261
    Nice install.... I like the Taco zone valves....don't see too many of those being install these days....there great valves
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
    newagedawn
  • Mad Dog_2
    Mad Dog_2 Member Posts: 6,970
    Pretty sqaured away. Very good job, man. Mad. Dog
    newagedawn
  • New England SteamWorks
    My nitpick: Next time try putting your purge station on the supply just before the air scoop with a shutoff between. Works like a charm.
    When you purge on the returns you won't be able to purge through the boiler, and usually there is a big old air pocket in there.
    Otherwise, looks very nice.
    newenglandsteamworks.com
    newagedawn
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,646
    edited November 2017
    I like piping the indirect as a zone with a valve. Also I've had great luck with the stainless Heat-Flo indirects, very well made.
    Only beef: I've found that copper female adapters to leak in a few years, especially on the indirect. I use iron couplings on the heating side and brass couplings on the domestic side with copper male adapters.
  • newagedawn
    thanks for the insight, "Quote" rel="EBEBRATT-Ed"> blowdown pipe on indirect relief valve,
    good eyes my friend have to go back to do that very thing,lol
    in this area they are popular, so i use em
    i agree but that air seperator is a great thing, works great!!!
    yes, heat flo is a great value, ive been using them for yrs now and no problems yet!!! and they have great recovery rates even with 3/4 pipe,lol
  • newagedawn
    replaced a 1950's clunker that would have outlasted me, but just isnt efficient anymore
  • newagedawn
    good eyes my friend, going back to do that very thing,lol
  • newagedawn
    yes, they are popular around this area
  • newagedawn
    yes your spot on, but that air seperator works wonders
  • newagedawn
    heat flo's are a great value,been using them for a while and no problems yet, and the recovery is awesome even with 3/4 pipe
  • Ironman
    Ironman Member Posts: 7,376
    Nice work!
    Have you tried the new style Taco Zone Sentry valves?
    Bob Boan
  • EzzyT
    EzzyT Member Posts: 1,295
    Nice work as others have mentioned, the one major thing I would’ve liked to see is at lest 12x the pipe diameter of straight pipe on the pump discharge before a fitting or valve.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
