from rags to riches
Nice install.... I like the Taco zone valves....don't see too many of those being install these days....there great valvesASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
My nitpick: Next time try putting your purge station on the supply just before the air scoop with a shutoff between. Works like a charm.
When you purge on the returns you won't be able to purge through the boiler, and usually there is a big old air pocket in there.
Otherwise, looks very nice.New England SteamWorks
newenglandsteamworks.com-1 -
I like piping the indirect as a zone with a valve. Also I've had great luck with the stainless Heat-Flo indirects, very well made.
Only beef: I've found that copper female adapters to leak in a few years, especially on the indirect. I use iron couplings on the heating side and brass couplings on the domestic side with copper male adapters.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
thanks for the insight, "Quote" rel="EBEBRATT-Ed"> blowdown pipe on indirect relief valve,
good eyes my friend have to go back to do that very thing,lolPaul S said:Nice install.... I like the Taco zone valves....don't see too many of those being install these days....there great valves
in this area they are popular, so i use em
i agree but that air seperator is a great thing, works great!!!New England SteamWorks said:My nitpick: Next time try putting your purge station on the supply just before the air scoop with a shutoff between. Works like a charm.
yes, heat flo is a great value, ive been using them for yrs now and no problems yet!!! and they have great recovery rates even with 3/4 pipe,lolSolid_Fuel_Man said:I like piping the indirect as a zone with a valve. Also I've had great luck with the stainless Heat-Flo indirects, very well made.
Only beef: I've found that copper female adapters to leak in a few years, especially on the indirect. I use iron couplings on the heating side and brass couplings on the domestic side with copper male adapters."The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0 -
replaced a 1950's clunker that would have outlasted me, but just isnt efficient anymore"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
good eyes my friend, going back to do that very thing,lolEBEBRATT-Ed said:Looks good!! Nice and neat. What did you replace??
a couple of nitpicks
Id rather see a pc of 1/2" EMT or PVC conduit run from the indirect up to a floor joist as a sleeve for the low voltage going to the indirect instead of the tyraps on the cold water line"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0 -
yes, they are popular around this areaPaul S said:Nice install.... I like the Taco zone valves....don't see too many of those being install these days....there great valves
yes your spot on, but that air seperator works wondersNew England SteamWorks said:My nitpick: Next time try putting your purge station on the supply just before the air scoop with a shutoff between. Works like a charm.
Otherwise, looks very nice."The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0 -
heat flo's are a great value,been using them for a while and no problems yet, and the recovery is awesome even with 3/4 pipeSolid_Fuel_Man said:I like piping the indirect as a zone with a valve. Also I've had great luck with the stainless Heat-Flo indirects, very well made.
Nice work!
Have you tried the new style Taco Zone Sentry valves?Bob Boan
Nice work as others have mentioned, the one major thing I would’ve liked to see is at lest 12x the pipe diameter of straight pipe on the pump discharge before a fitting or valve.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
