Steam replacement
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Beautiful install as always @Dave0176.
I like the water seal you have on that boiler.1 -
Beautiful. I like the VXT nice and high against the wall, easy to see and work with. Picture perfect.New England SteamWorks
newenglandsteamworks.com1 -
Thank you Ez for teaching us pigtails suck.......EzzyT said:Beautiful install as always @Dave0176.
I like the water seal you have on that boiler.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
No, it’s to modulate the fire to maintain between 4-10 oz steam pressure. Starts on high fire as pressure rises in the system when it reaches 10 oz the Vaporstat kicks the fire to low.MilanD said:Beautiful, @Dave0176! Why 2 stage it? Are there zone valves or TRVs on the rads?
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Nice install.0
Dave, Very nice work. Just wondering what is Wardflex?0
@Phil53 Ward Flex is Wards version of flexible gas line aka CSST (corrugated stainless steel tubing).Phil53 said:Dave, Very nice work. Just wondering what is Wardflex?
Ahh, got it. Thanks!! I didn't think it was needed on properly sized boiler. We have it and does great with zones. When all are calling, never above 8 oz. With 1 zone closed, modulates at 8. Super nice. I suppose I never thought to modulate even with all zones calling. I'll play with that this winter.0 -
beautuful installation @Dave0176ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Looks great! I would love to do this one day!0
I think there's a good argument that you size for load & a healthy 50% pickup, but then down fire just to match load only... plus you could use a few TRV's for rooms with varying heat loses or small sizes like kitchens and bathrooms.MilanD said:> @Dave0176 said:
How much pressure you need is then just a matter of the size of your header relative to the boiler size and size of your vents.
Beautiful install. Like the 2 supply's to the header. It's not a large boiler but I'll bet the steam is nice and dry with the extra pipe.0
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
