Steam replacement
Dave0176
Dave0176 Member Posts: 1,178
edited October 2017 in Strictly Steam
2007 installed Burnham V84 boiler, rotted on one section and starting to corrode on the others. He decided to convert to gas, we installed a Union Steam GSA 125,000 (EG40) I’m also going to put a two stage gas valve when my parts arrive. Totally finished basement so we had to snake Wardflex through the rafters to get gas to the boiler, all went well, but was back breaking job.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Paul S_3LionA29StuckWithSteam
  • EzzyT
    EzzyT Member Posts: 1,367
    Beautiful install as always @Dave0176.
    I like the water seal you have on that boiler.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Dave0176
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,528
    Beautiful. I like the VXT nice and high against the wall, easy to see and work with. Picture perfect.
    newenglandsteamworks.com
    Dave0176
  • Dave0176
    Thank you Ez for teaching us pigtails suck.......
    Paul S_3
  • EzzyT
    I can't take the credit for that.
    201-887-8856
    Danny ScullyPaul S_3
  • MilanD
    MilanD Member Posts: 1,162
    Beautiful, @Dave0176! Why 2 stage it? Are there zone valves or TRVs on the rads?
  • Dave0176
    No, it’s to modulate the fire to maintain between 4-10 oz steam pressure. Starts on high fire as pressure rises in the system when it reaches 10 oz the Vaporstat kicks the fire to low.
  • Dale_3
    Dale_3 Member Posts: 58
    Nice install.
  • Phil53
    Phil53 Member Posts: 73
    Dave, Very nice work. Just wondering what is Wardflex?
  • MilanD
    edited October 2017
    Csst gas line brand.
  • Dave0176
    @Phil53 Ward Flex is Wards version of flexible gas line aka CSST (corrugated stainless steel tubing).
  • MilanD
    Ahh, got it. Thanks!! I didn't think it was needed on properly sized boiler. We have it and does great with zones. When all are calling, never above 8 oz. With 1 zone closed, modulates at 8. Super nice. I suppose I never thought to modulate even with all zones calling. I'll play with that this winter.
  • Paul S_3
    Paul S_3 Member Posts: 1,288
    beautuful installation @Dave0176
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • jgach11886
    jgach11886 Member Posts: 13
    Looks great! I would love to do this one day!
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    edited November 2017
    I think there's a good argument that you size for load & a healthy 50% pickup, but then down fire just to match load only... plus you could use a few TRV's for rooms with varying heat loses or small sizes like kitchens and bathrooms.
    How much pressure you need is then just a matter of the size of your header relative to the boiler size and size of your vents.
    Beautiful install. Like the 2 supply's to the header. It's not a large boiler but I'll bet the steam is nice and dry with the extra pipe.
