Steamer repipe
EzzyT
Member Posts: 1,377
We repiped this oversized 3 year old boiler and added 2 stage firing to cut down on the short cycling.
Going back tomorrow to upgrade the main venting, skim the boiler and combustion analysis.
2
Have to love the beauty of black iron on a steam boiler...just a quality job done by a pro...;)0
Always nice to make a few bucks back on that scrap copper lol very nice, EzzDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
looks good. first class job0
Now that is sweet! Nice work.
Hard to believe the original installer put a skim port on after botching everything else...
How hard to get the original risers out? I always dread that part. Did you have to cut them?New England SteamWorks
newenglandsteamworks.com0 -
Thanks @EBEBRATT-Ed and @New England SteamWorks
The original install was a tech that I used to work with.
They weren't to bad since they were in only 3 years. No I wrenched them out the 3' did the job.0 -
You know, -it's getting harder to keep up with your pressuretroll/gauge trees, btw!New England SteamWorks
There pretty basic nothing special about them0
Very nice work! Love the staging.
Lovely! Can I call it lovely?
Just awesome!
2 qs: at what op pressure low fire kicks in and what gas valve did you use on it?0 -
Thanks @AMservices and @MilanD.
Low fire kicks in at 8oz and it's a Honeywell 8345Q4563 2 stage gas valve.-1 -
Another nice job.All Steamed Up, Inc.
Consulting0 -
is there a certain distance you need to kick down before raises back up to your controls? also, is the chimney lined?0
Thanks Frank.
Just have to drop down enough to create a water seal/trap. Yes the chimney is lined0 -
cool thanks00
beautiful job @EzzyTASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
