Old oil to gas conversion boiler with Economite E20.
Oil_to_gas_1
Member Posts: 1
I hope someone can assist. I have a very old boiler which used to burn oil but was converted to gas. It has an Economite E-20 gas conversion motor that was installed long ago. It broke! I am able to get a new Economite E 20 motor but can't find a motor bracket that fits perfectly. The ones we have found seem to sit too high. There are nuts and bolts on top of the E-20. Are those supposed to be removed? I don't understand why the parts don't fit. Help please.
The E20 is not my favorite burner. Most installations of this burner that I've encountered were not done properly- lots of flame impingement, poor combustion etc.
What make and model is the boiler?All Steamed Up, Inc.
Consulting1 -
Time for an upgrade, if the boiler doesn't have a steel chamber.
Post pics.0 -
the bolts are welded to motor rubber discs with brass sleaves suport the motor wire clips hold the rubber nuts not needed0
Get in touch with me at 401-437-0557 I have all kinds of information on the E-20. I have installed thousands of them in the past.0
