Old oil to gas conversion boiler with Economite E20.
Oil_to_gas_1
Oil_to_gas_1 Member Posts: 1
edited September 2017 in Gas Heating
I hope someone can assist. I have a very old boiler which used to burn oil but was converted to gas. It has an Economite E-20 gas conversion motor that was installed long ago. It broke! I am able to get a new Economite E 20 motor but can't find a motor bracket that fits perfectly. The ones we have found seem to sit too high. There are nuts and bolts on top of the E-20. Are those supposed to be removed? I don't understand why the parts don't fit. Help please.
    Steamhead Member Posts: 18,495
    The E20 is not my favorite burner. Most installations of this burner that I've encountered were not done properly- lots of flame impingement, poor combustion etc.
    What make and model is the boiler?
    Consulting
    HVACNUT
    HVACNUT Member Posts: 7,441
    Time for an upgrade, if the boiler doesn't have a steel chamber.
    Post pics.
  • Dan467
    Dan467 Member Posts: 11
    the bolts are welded to motor rubber discs with brass sleaves suport the motor wire clips hold the rubber nuts not needed
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Get in touch with me at 401-437-0557 I have all kinds of information on the E-20. I have installed thousands of them in the past.
