What wrench to use for this spud?
What wrench do I need to attach this spud? It does not have the nubs that a traditional spud uses. Thanks.
  • EzzyT
    EzzyT Member Posts: 1,367
    A torc tip should work
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    steamhouse
  • steamhouse
    steamhouse Member Posts: 41
    Where can I get one? Could you recommend a site online?
    Steamhead Member Posts: 17,801
    Try a 3/8" socket wrench extension.
    Consulting
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,281
    or a 1/2 " socket extension or a square seat wrench used for faucets with washers and seats.
  • steamhouse
    Yes. Socket it was
    EBEBRATT-Ed Member Posts: 17,861
    or square stock grind until it fits
  • mars_6
    mars_6 Member Posts: 107
    Dependant on what size spud it is you may find that the corresponding size black iron plug may work. You put the plug into a coupling and thread it in that way. Just a thought.
