Running 1/2" PEX through a 3/4" PEX chase
Scienceman
Scienceman Member Posts: 1
I used Watts 3/4" radiant PEX between the 2nd floor and the basement in a 200+ year old house as a chase for 1/2" Wisbro hePEX. Will this be a problem as a result of differential rates of expansion? I did not want the Wisbro PEX to be abraded as it was fed through this chase to and from the header.
  • kcopp
    kcopp Member Posts: 4,685
    IF you can get the tubing through there you will be fine.
    EBEBRATT-Ed Member Posts: 20,210
    doubt it will fit but go for it
  • Zman
    Zman Member Posts: 7,610
    I have done short sections like that to avoid abrasion from metal plaster lathe. It worked just fine.
    Albert Einstein
  • PatN
    PatN Member Posts: 20
    I have used ENT tubing for sleeving pex many times. l
    Carlon
    3/4 in. x 100 ft. ENT Coil - Google carlon ent/smurf tube
    ratio
