Running 1/2" PEX through a 3/4" PEX chase
Scienceman
Member Posts: 1
in Plumbing
I used Watts 3/4" radiant PEX between the 2nd floor and the basement in a 200+ year old house as a chase for 1/2" Wisbro hePEX. Will this be a problem as a result of differential rates of expansion? I did not want the Wisbro PEX to be abraded as it was fed through this chase to and from the header.
IF you can get the tubing through there you will be fine.0
doubt it will fit but go for it0
I have done short sections like that to avoid abrasion from metal plaster lathe. It worked just fine."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
