Best high-temp aluminum foil tape
D107
Member Posts: 1,944
Suggestions on brands and where to buy? Need for breeching extra sealing, covering breeching test holes, etc. So far Heat Shield product 340110 seems best--up to 1000 degrees.
I try to stay away from foil tape unless absolutely necessary for temporary repairs and such. 3 screws in each joint and furnace cement at the breach.0
High temp foil tapes seem to have a bad rep and I'm not sure if it's justified.
I put 3M high temp foil tape over some test holes on and near my drafthood a few years back and not only did it not fall off, it's extremely hard to get off, almost like the glue cured with heat.
The cheap stuff falls off, just as with "duct tape" but that doesn't mean good products will fail.
When you start spending $30-40 on a small roll of tape, the quality isn't the same as cheap stuff.
@Dave0176 All of the ones I've found are rated up to 600F continuous. That isn't high enough?
-1 -
@ChrisJ, thanks, yes 600 is plenty high for temps that rarely go over 300. The particular one I found happened to go to 1000; another one only to 260. Just looking for a few brands, have only found two so far. Some good chimney guys prefer not to use any foil tape permanently. I sort of agree and would be using this temporarily or only to cover test holes.0
@STEVEusaPA Have you tried 3M's high temperature flue tape, which is rated to 600F, the same as red RTV?
-1 -
Sure, I have a roll.ChrisJ said:@STEVEusaPA Have you tried 3M's high temperature flue tape, which is rated to 600F, the same as red RTV?
I have some foil tape stuck on a glass skylight, and I am wondering how to get it off. Maybe using a heat gun would not be the best way, if the adhesive is cured with heat.
Any suggestions?--NBC0 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
