The Mills Steam-Heating System
HeatingHelp
HeatingHelp Administrator Posts: 717
edited July 2017 in THE MAIN WALL
Read the full story here
  • StephenPelosa
    StephenPelosa Member Posts: 20
    I wish I could have seen a picture of that. Amazing!
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,682
    I'm still smiling!
    Retired and loving it.
    HVACNUT Member Posts: 7,201
    That's nuts. I think you're a L.I. guy Dan. There's a supplier in Medford, Hasko Utilities. Not to the extent of those old 12" fittings, but Dave the owner has some of the most obscure parts. If you bring in something weird, if he doesn't have it, he can usually make something work for you to use. I've never been in the warehouse, but I'm sure its a treasure trove. And he's a great guy to boot.
  • DanHolohan
    Ah, Dave. One of the best!
  • BobC
    BobC Member Posts: 5,538
    Great story, Dan. i can't imagine what it would have been like if he didn't get that old vent back on that pipe in time.
    Today you just put a couple of bigmouth vents up there
    Bob
    3PSI gauge
    RomanGK_26986764589
  • DanHolohan
    Scary day in a small space. ;-). Thanks, Bob.
    MilanD
    EBEBRATT-Ed Member Posts: 19,455
    I have read that story several times. It's always one of my favorites.
    RomanGK_26986764589
  • DanHolohan
    Thanks
    Steamhead Member Posts: 18,184
    Did we ever find out who made that football-sized vent?
    Consulting
  • DanHolohan
    No, but it reminded me of the big Trane vent.
  • gerry gill
    gerry gill Member Posts: 3,083
    edited July 2017
    Good thing Tommy listened and put the cork back in the bottle!!
    gwgillplumbingandheating.com
  • DanHolohan
    Oh, yeah.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    How was the main venting handled on the down risers?--NBC
  • DanHolohan
    With main vents above the waterline.
  • MilanD
    MilanD Member Posts: 1,162
    "PUT IT BACK!"
    Love it!
  • JUGHNE
    JUGHNE Member Posts: 11,508
    With my luck the 3/4 would have twisted off and then the steam would come up! :o
    MilanD
  • jumper
    jumper Member Posts: 2,498
    Do you need a vent at the top of an overhead distribution steam system? Why not a menorah in boiler room? Or near bottom of each down riser?
  • DanHolohan
    We have to vent where the air is going, not where it's been.
    Of course the air is going first up to the top, and then down the risers, so menorahs of basement located main vents would probably work, and be more convenient to monitor.
    Careful attention would be needed to the main venting capacity on each down riser, so that the system would be balanced, and not favor one vertical stack of radiators over another.
    Still the 3/4 inch vent at the top probably should have been more capacious now in the age of gas fired on-off boilers.--NBC
