The Mills Steam-Heating System
HeatingHelp
Administrator Posts: 650
I wish I could have seen a picture of that. Amazing!0
I'm still smiling!Retired and loving it.0
That's nuts. I think you're a L.I. guy Dan. There's a supplier in Medford, Hasko Utilities. Not to the extent of those old 12" fittings, but Dave the owner has some of the most obscure parts. If you bring in something weird, if he doesn't have it, he can usually make something work for you to use. I've never been in the warehouse, but I'm sure its a treasure trove. And he's a great guy to boot.0
Ah, Dave. One of the best!Retired and loving it.0
ThanksRetired and loving it.0
Did we ever find out who made that football-sized vent?All Steamed Up, Inc.
Consulting0 -
No, but it reminded me of the big Trane vent.Retired and loving it.0
Good thing Tommy listened and put the cork back in the bottle!!gwgillplumbingandheating.com
Oh, yeah.Retired and loving it.0
How was the main venting handled on the down risers?--NBC0
With main vents above the waterline.Retired and loving it.0
"PUT IT BACK!"
Love it!0 -
Do you need a vent at the top of an overhead distribution steam system? Why not a menorah in boiler room? Or near bottom of each down riser?0
We have to vent where the air is going, not where it's been.Retired and loving it.0
Of course the air is going first up to the top, and then down the risers, so menorahs of basement located main vents would probably work, and be more convenient to monitor.
Careful attention would be needed to the main venting capacity on each down riser, so that the system would be balanced, and not favor one vertical stack of radiators over another.
Still the 3/4 inch vent at the top probably should have been more capacious now in the age of gas fired on-off boilers.--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 27 Recall Announcements
