I get by with help from my friends.
No shade at all
The Ecosteam sneaks it's way into air conditioning.
Right now, it opens Y1 at 62F and closes at 70F.
We'll see how that works for normal use.
He is delicate but a 66* DP with 87% Rh is a far cry more uncomfortable than 60* DP and 70% RH Mr K .Gordy said:Sitting on the patio drinking hot coffee. You must be very delicate........
732-751-1560
Rich McGrath 732-581-38332 -
Ok good, we all agree I'm delicate.Rich said:
I have no problem with honesty.
Although............I was up in the 111F attic today for a short while pulling wire, so I think I get a few points for that.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I'll give you points @ChrisJ There's no way I'm going in the attic at this time of year unless I have toYou can have it good, fast or cheap. Pick two-1 -
Rich said:
Bah Mr. M. Sitting at the patio drinking Franziskaner wishing the dew point was higher. Something about an ice cold wheat beer, or any beer for that matter sweating on the bottle makes it more presentable. I like balmy. As you get older it's much more palatable than below zero.
What you go up to see if your anti perspirant works? Get done, and out of there......you could probably use a container of monkey butt.
> That wiring is a mess you need to clean that up. Certainly not to ChrisJ spec......
I apologize for the crudity of this model I didn't have time to build it to scale or paint it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
JUGHNE said:
Just don't fall off the toilet! You might break the clock.
Here we are 102 actual with feel like 102.
But RH at 21 with DP at 54. Dryer than usual....grass fire time.
I just came in from outside and this room feels uncomfortable at 77 degrees. That is my Tstat setting.....my wife's is set at 74.
2 -
Bright and early it's 74F, 80% RH outside.
Inside, 72F and 43%.
Attic : 75F 42%.
So,
Another example of humidity
This is in one of the bedrooms, which I intentionally keep cooler than the first floor.
Under most conditions, I have no problem pulling those bedrooms down to 68F with decent humidity.
Outside was just splendid
Those highs and lows reset at midnight and this was around 6AM.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Your return and supply are vastly over sized. Why have a 3 ton air handler with 800 cfm 1000 would be my minimum and 1200 would be better.0
Yes, my supplies and returns are oversized.unclejohn said:Your return and supply are vastly over sized. Why have a 3 ton air handler with 800 cfm 1000 would be my minimum and 1200 would be better.
Like I said in the other thread, air flow isn't a concern.
I'm confused by your "why have a 3 ton air handler" comment though? Because that's what the house needs?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
