Must AC handler float switch be in contact with air handler for grounding?
D107
Member Posts: 1,945
See photo. A contractor broke the condensate drain connection, so I had to reglue it back together after cleaning out inside handler. So now I'm wondering if the float switch has to be in contact with unit for grounding and keeping it in one place?
It should be mounted to keep it in place. That bracket looks like it was field fabricated to hold that float switch since it couldn't clamp onto the side of the pan. As for grounding, I'm not positive if it's required, but there isn't much exposed metal on that float switch and it isn't provided with a means of grounding nor is grounding addressed in the instructions (if that's the same model I've used, it looks like it).
Slide it over until a hole lines up with a screw on the door.
-1 -
Yes this is an ACS-2 Auxiliary Condensate Drain Pan Overflow Shut-off Switch with 18" leads. by Little Giant Pump Co. 48V AC/DC 5.0 A max. Seems to be connected to low voltage T-Stat wires. Not sure what that white foam piece is--part of float I guess. See photos. I attached it to handler via screw hole to stabilize it.
Huh. The switch itself is an of the shelf part, but I don't think that white foam block came with the switch—unless that is a factory accessory kit, IDK. It does looks like it (the foam & bracket) were made to go in there like that. Maybe it's not the switch I'm thinking of.
In any case, I hear that the NEC doesn't require grounding, I'd only be concerned with mechanical stability of the switch, to keep it from moving, so that the float can do what it's supposed to do in the unfortunate event of water getting into the aux pan.
-1 -
That bracket was field fabricated because the sandwich clamp couldn't attach to the pan. Is that bracket secured to the A/H? If not, it won't do its job. I like to use the "hockey puck" style water sensors. Just lay it in the pan, and your done. They are 24v. powered, and need a 4 wire.
Also, in my opinion, I like to break Y and not R, so if there's a freeze up, the fan will continue to run so you don't get Niagara Falls.-1 -
Thanks; yes did attach with screw.0
- 117 Geothermal
