can someone help me i need to find out if i could use a n
Anthonymarquez1980
Member Posts: 1
in Gas Heating
can someone help me i need to find out if i could use a natural gas regulator with 4'' wc to a 5lb meter ? this is for a 48'' range stove
When you say a natural gas regulator are you talking about an appliance regulator? What is the make and model of the regulator and its pipe size? Is this a commercial gas range and if so what does the rating plate on the range call for as to pressure?0
732-751-1560
Rich McGrath 732-581-38330 -
A picture of what you have both at the appliance and meter would really help.
If you in fact have 5# pressure in the house (that would be different), the regulator that came with the appliance will not work.
You would need a step down regulator at some point in the system."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
