can someone help me i need to find out if i could use a n
can someone help me i need to find out if i could use a natural gas regulator with 4'' wc to a 5lb meter ? this is for a 48'' range stove
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    When you say a natural gas regulator are you talking about an appliance regulator? What is the make and model of the regulator and its pipe size? Is this a commercial gas range and if so what does the rating plate on the range call for as to pressure?
  • Rich_49
    Rich_49 Member Posts: 2,783
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
  • Zman
    Zman Member Posts: 7,614
    A picture of what you have both at the appliance and meter would really help.
    If you in fact have 5# pressure in the house (that would be different), the regulator that came with the appliance will not work.
    You would need a step down regulator at some point in the system.
    Albert Einstein
