low voltage wiring question
hot_rod
Member Posts: 24,663
Does 12VDC wiring in a RV or tiny home need to be in conduit? Seems like NEC 2017 tried to clarify that, anybody have the art # or section? thanks
I believe it depends upon the connected wattage, but I will defer to a watthead for a correct answer.
ME0 -
Don't have the 2017 yet. But any RV I have seen does not have conduit for conductors. Just wiring as any motor vehicle would have. Common sense should prevail for protection of wires though. However stranded wire is always used due to vibration.
As ME mentioned the wattage, #10 AWG @ 30 amps would only deliver 360 watts comfortably.
Even the 120VAC wiring is just Romex type cable, only stranded wires, maybe called boat wiring cable? FWIW0 -
I once saw an old work receptacle, used for RVs. I should have bought it. It was just like it sounds, mounted in the plaster ears were old work dogs.0
That was my thought also, RV wiring. I used #10 fine stranded Southward brand low voltage wire. It is sold for outdoor low voltage lighting, rated to 30V.JUGHNE said:Don't have the 2017 yet. But any RV I have seen does not have conduit for conductors. Just wiring as any motor vehicle would have. Common sense should prevail for protection of wires though. However stranded wire is always used due to vibration.
5A fuse on all the receptacles which are cigarette lighter type plugs used in the marine industry. 30A fuse on the battery feed to fuseblock with #8 wire.
Conduit would only be needed for physical protection. Just cannot run conductors of different voltages in the same conduit, although there are exceptions to that rule.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
It's covered in article 551.47 of the NEC. My most recent copy is the 2011 edition. I'm not sure if the 2017 is available yet, and if it is, it's doubtful that it's been adopted by your state yet. They all vary on that, so you would have to confirm that.
In the 2011, I see no such requirement. The best source for a definitive answer is Mike Holt.
Mikeholt.comBob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
