Steam from the Sun, and a Possible Use for Carbon Monoxide?
  • ChrisJ
    ChrisJ Member Posts: 17,070
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Let's hope it is not eight!!!--NBC
    ChrisJTim Potter
  • ChrisJ
    I didn't even consider that.................
    Ugh.
    Jamie Hall Member Posts: 26,838
    If they can make the process work, it does suggest another avenue for solar power. Whether or not it would be more cost-effective and energy efficient that using solar generated electricity to perform hydrolysis remains to be seen.
    For those with longer memories -- or more reading -- I might venture to point out that coal gas (which had a lot of environmental problems and is, thankfully, long gone!) was a mixture of carbon monoxide and hydrogen produced by heating coal in a reducing atmosphere. The Fischer-Tropsch process can be used to convert that mixture into liquid hydrocarbons, and is currently in commercial use in several countries.
    I see that a couple of the comments appear to have political overtones, which is unfortunate. It might be preferable to have the economics and real environmental impacts speak for themselves?
  • jumper
    jumper Member Posts: 2,501
    Sounds more difficult than harvesting algae.
