check out this piping and insulating
hot_rod
Member Posts: 27,593
at a job I visited last week in Colorado that Pete "the heat" Stout Mechanical. Perfect layout, pipefitting and some of the nicest pipe insulating I have ever seen, perfect miters, very little plaster.
Prob Zeston covers. Well done.0
I didn't mean to put it in the heating hell cat, sorry. I don't see a way to edit that?Bob "hot rod" Rohr
An @moderator should be able to move it.0
Moved this to the Main Wall. Nice Work!
President
HeatingHelp.com0 -
nice work..... @hot rod is this geothermal? i dont see any by me in NYC....i read about it in some idronics.ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
It's a four pipe system able to provide heating and cooling at the same time, when required.Paul S said:nice work..... @hot rod is this geothermal? i dont see any by me in NYC....i read about it in some idronics.
Ground source heat pumps, one Viessmann boiler, a solar thermal component and HXers for a salt water pool system all tied in. A Siemens control system runs it all.
Living the hydronic dream1 -
Pete is good guy! Glad to see his work featured here, he deserves it!0
Usually split on the inside of the turn and it looks like PVC tape.Hatterasguy said:They are beautiful.
What does he use to secure those 90 degree and 45 degree covers? They must be split somewhere?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Looks like professional pipe coverers work. On big jobs like a hospital or something the bid for pipe covering installed is close to the bid for the pipe installed.
Around here, the price for the 1" itchy is more than the copper.
$_$
I've still got some in the box in my crawlspace I haven't finished because it's so awfully fun to work with.
I want to change my name to pete just to have the nickname "pete the heat"!0
They have special thumb tacks that have little barbs on them. Usually just use tape on chilled water to provide a vapor barrier.
Not that I do much insulating, but trying to put the thumb tack in while holding the fitting cover and getting it tight can be a challenge (plus you need strong thumbs!!!!!!)
One thing I finally found out that makes things much easier is to put the thumb tack through the first layer of the fitting cover , then put the cover in place and then push the tack through the second layer.
It only took me 30 years to figure that one out. I am sure many of you are smarter than me.
They also sell the white mastic in a bucket that you apply with a paint brush, fills in all the gaps. It's a real savior.
Real nice job!!0 -
My helper was getting a sore thumb with those tacks.
He was given my pocket flashlight with the magnet on the end to use as a holder and gave him a good handle to push with.
Sensible Products EMF-1 or EMF-2.
Can't leave home without it......telescopes from 6.5" to 22"
has flex flashlight on the end......magnets on each end for old fat men to pick up dropsies.0 -
Now if I could just find someone to bend over and pick things up for me and carry my tools.............and get me coffee0
Grandchildren.......
I'll be retired by the time there old enough. Besides, you wouldn't expect them to get dirty.0
You can get some young-uns to do grunt work. I have a nephew that could have taught Mike Rowe a thing or two about dirty jobs.
My nephew was a skinny kid and their septic tank had a smallish manhole cover. My brother in-law used to lower him through that manhole cover while he held a sump pump in his hands to pump the septic out when the water table was high.
I can still hear him yelling "For God sake, don't drop me!"
3PSI gauge0 -
This one will get dirty.....if he gets whiney I will talk to his parents.
They will straighten him out as his father has already suffered the same fate 20-30 years ago and although may not admit it is glad he had to work in the trades.
There is still hope for the future.
Just not enough of them like this.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
