too much renewable
jumper
jumper Member Posts: 2,539
In central Europe Germany's copious wind power messes up grid.
    Jamie Hall Member Posts: 27,372
    edited February 2017
    It's an interesting ( >:) ) problem. Distributed smaller renewable energy sources are wonderful, but unless there is some really solid generating capability feeding the grid, you run into some really fascinating frequency and phase control problems. Even paralleling two or more generators close together can get tricky -- if they are separated by any significant distance... and it all has to run perfectly, all the time, untended.
  • ChrisJ
    ChrisJ Member Posts: 17,380
    Thomas Edison and others had a lot of problems getting generators to cooperate with each other early on.
    They didn't give up though.
  • Paul48
    Paul48 Member Posts: 4,469
    He just had to ask Tesla :wink:
    ChrisJ
    Didn't say it couldn't be done -- it's done all the time. Just that there are some interesting (!) problems associated with doing it.
    ChrisJ
