too much renewable
jumper
Member Posts: 2,472
In central Europe Germany's copious wind power messes up grid.
It's an interesting (
) problem. Distributed smaller renewable energy sources are wonderful, but unless there is some really solid generating capability feeding the grid, you run into some really fascinating frequency and phase control problems. Even paralleling two or more generators close together can get tricky -- if they are separated by any significant distance... and it all has to run perfectly, all the time, untended.
Thomas Edison and others had a lot of problems getting generators to cooperate with each other early on.
They didn't give up though.
Didn't say it couldn't be done -- it's done all the time. Just that there are some interesting (!) problems associated with doing it.ChrisJ said:Thomas Edison and others had a lot of problems getting generators to cooperate with each other early on.
They didn't give up though.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
