Mixing 1/2 PEX and 3/4 PEX in a single zone
dgkula
Member Posts: 59
Question for the pros please: I have a single zone in my basement which is plumbed off a manifold with 1/2 PEX to 15' of fin tube (based on 3/4 copper pipe). I want to add a second radiator to this zone to heat a soon to be finished area of the basement. A plumber has proposed adding 8' fin tube and running 3/4 PEX, splicing that into the return from the 1/2 PEX, creating a single loop consisting of source >1/2 PEX > 3/4 fin tube > 1/2 PEX > 3/4 PEX > 3/4 fin tube > 3/4 PEX > return. Is this going to be OK? Naively I would think that single diameter for the whole run would minimize changes in pressure throughout the zone for a constant flow rate but I don't know if it matters. Of course an option is to have him re-plumb the original 1/2 for 3/4 PEX so that all diameters are the same but I have read that PEX expands as it heats ...
Thanks!
David
Thanks!
David
Your 23' of baseboard will put out round 13,000 btu. You only need to move around 1.3 gpm. That should be easy with the piping you described."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
