Heat loss on return side of radiant syatem
enzo
Member Posts: 4
I have a Baxi 310 , running 3 loops of pex radiant off a manifold. Each loop is between 260 and 275 feet. With a Taco 007 circ. My problem is drop i ntemperature on return side is over 50 degrees. The pex is 1/2" in aluminum plates, with foil barrier and 6" fiberglass insulation in each bay. The area below living area is a basement. Why is my temperature drop so great??
Got some pictures of the near boiler piping, manifold etc?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 52 Job Opportunities
