Heat loss on return side of radiant syatem
enzo
enzo Member Posts: 4
I have a Baxi 310 , running 3 loops of pex radiant off a manifold. Each loop is between 260 and 275 feet. With a Taco 007 circ. My problem is drop i ntemperature on return side is over 50 degrees. The pex is 1/2" in aluminum plates, with foil barrier and 6" fiberglass insulation in each bay. The area below living area is a basement. Why is my temperature drop so great??
    Jamie Hall Member Posts: 27,750
    Low flow. Now you need to find out why...
    EzzyT
  • Solid_Fuel_Man
    Got some pictures of the near boiler piping, manifold etc?
  • Zman
    Zman Member Posts: 7,614
    Do you have a mixing valve on the radiant loop? If so which model?
    Albert Einstein
    Gordy
