Minimum distance between 2 boiler vent?
Jacob777
Member Posts: 1
I'm installing two Burnham Alpine condensing boilers in multifamily. I know that distance between air intake and exhaust must be more than 12 inches. I wonder if there's a minimum distance between two boiler's intake and exhaust? I'm in the state of MA,Thank you!
Check your local codes. There may be something in there. Otherwise, so far as I know, the two intakes can be close together, and likewise the two exhausts -- so long as the exhaust to intake spacing is adequate.Br. Jamie, osb
Not sure about MA as the laws of physics are slightly different there
. In most areas the manufactures installation instructions take precedence. It is a good idea to separate the intakes and exhaust as far as you reasonably can. Cross contamination will destroy your boilers. "If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
