Electric Radiant Question
Hello,
I am considering using electric radiant floor in my master bathroom (on a timer or set schedule). Can anyone here suggest a product that has proven to be fairly dependable and reliable? I don't anticipate the heat load to be large.
Thanks.
    Jamie Hall Posts: 27,747
    May I enquire where you are located, and what heating system you have for the rest of the structure? The main reason I ask is that in much of the United States and Canada, the cost of operation of electric heating -- radiant or otherwise -- is very much greater than the cost of other options. In Quebec, this is not true, however. So the "where" does make a difference. The what heating question is this: if you have hot water or steam for the rest of the house, it may be much more efficient to use a hot water radiant system.
  • Zman
    Zman Posts: 7,614
    I have used the Suntouch products and had good luck. http://www.suntouch.com/
    If you are using it for space heat , because the room has exterior surfaces and has an actual heat loss, I would suggest a room t-stat.
    If you are just going for the "warm floor" feel on an interior bath, a timer would be a good choice.
    It is fairly common for the mat to be damaged by the tiling or other contractors.
    Have your electrician check and document the resistance rating of the mat as soon as it comes out of the box and when each trade completes their work. You will need this for the warrantee and it will keep the subs accountable.
    Albert Einstein
    hot_rod Posts: 28,224
    A Loud Mouth is a good accessory to use when installing electric cable or mat system. It lets you know before it is too late:)
    Zman
  • Or.... Use one of the plastic sheet type of heaters which are not as susceptible to damage... Most of the self limiting plastic sheet systems will change their resistance based on surface temperatures. So if you have a large room and part of the grid is directly in the path of sunshine, that part will automatically shut down and avoid waste and overheating the area to which it is connected.
    There is also a brass screen radiant heater out there that is less susceptible to damage, but is not self limiting.
    Curious as to wether or not you realize the difference in hourly cost of operation, It would be a deal killer for me in my location (Denver CO).
    ME
  • Gordy
    Gordy Posts: 9,546
    edited January 2017
    this product is nice, and can be nailed stapled through with out damage. The mesh that is.
    heatizon.com/zmesh-versatility.php
