Leaking furnace
Tbone_2
Member Posts: 5
Any thoughts on troubleshooting my furnace with this recent condensation leak before I call an hvac guy
Clogged or slightly obstructed drain?...improper drain setup...cracked heat exchanger anyone of theseASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
Do I need to gain access from other side of furnace to look if it's exchanger or drain. It's dripping from beneath that black panel/ housing0
How can you visibly tell if an heat exchanger is cracked. Don't need to be charged for something I may not need but a service guy may tell me I need?0
Have to admit that I can't tell much from that picture. Not even if this is hot air or hot water or steam... or if it's a condensing furnace or boiler or not.
Which leaves the possible source of that leak very much up in the air.
Can you provide more information?Br. Jamie, osb
Was there a hose or plug on this nipple that's now missing?
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Yes I removed it. Thought maybe it was blocked there. It leaking from below that area, the corner of the black where the housing and the gray . Is there a way to check if it's blocked in that drain area causing it to leak from below it0
Even if it were blocked, it shouldn't leak around the collector cover.Bob Boan
if it's GFA, do you have a humidifier installed?0
There are gaskets behind that cover. This could be an indication of a number of issues and probably best checked by a pro0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
