Leaking furnace
Tbone_2
Tbone_2 Member Posts: 5
Any thoughts on troubleshooting my furnace with this recent condensation leak before I call an hvac guy
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    Clogged or slightly obstructed drain?...improper drain setup...cracked heat exchanger anyone of these
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    Ironman
  • Tbone_2
    Do I need to gain access from other side of furnace to look if it's exchanger or drain. It's dripping from beneath that black panel/ housing
  • Tbone_2
    How can you visibly tell if an heat exchanger is cracked. Don't need to be charged for something I may not need but a service guy may tell me I need?
    Jamie Hall Member Posts: 26,844
    Have to admit that I can't tell much from that picture. Not even if this is hot air or hot water or steam... or if it's a condensing furnace or boiler or not.
    Which leaves the possible source of that leak very much up in the air.
    Can you provide more information?
  • Ironman
    Ironman Member Posts: 7,863
    Was there a hose or plug on this nipple that's now missing?
    Bob Boan
    rick in Alaska
  • Tbone_2
    Yes I removed it. Thought maybe it was blocked there. It leaking from below that area, the corner of the black where the housing and the gray . Is there a way to check if it's blocked in that drain area causing it to leak from below it
  • Ironman
    Even if it were blocked, it shouldn't leak around the collector cover.
    Bob Boan
  • Tbone_2
    Can that collector cover be removed without affecting rest of furnace. Should I turn off furnace 1st
    phosgene
  • Abracadabra
    Abracadabra Member Posts: 1,949
    if it's GFA, do you have a humidifier installed?
  • Ironman
    I'd recommend that you call a pro.
    Bob Boan
    phosgene
  • lchmb
    lchmb Member Posts: 2,997
    There are gaskets behind that cover. This could be an indication of a number of issues and probably best checked by a pro
  • John Mills_5
    John Mills_5 Member Posts: 952
    Shouldn't there be a hose running to a drain system?
    phosgene
