What manufacturer/model of furnace is this?
vodkanada
Member Posts: 3
For reasons that escape me, I cant find out who the maker of this furnace is. There's nothing written on it.
It's stopped heating the house, its just blowing cold air now. I assume the pilot light is out? But we know virtually nothing about these things, I was hoping if i could find out the maker I could find some steps to resolve the issue.
null
Holy crap, I apologize. I was having uploading problems. It should be up now.0 -
The pics have to be jpg's or pdf's and reasonable sized.
3PSI gauge0 -
There must be a nameplate on it somewhere. Did you take the cover off and look inside?
Regardless, you need a competent service tech0 -
Got some more pics. So this doesn't seem to be one where we light the pilot light, seems to do it itself.
There's a panel of diagnostic light codes, but nothing seems to be flashing.0 -
Looks like a York product, but none of your pics actually included the full model number.
Regardless, there's no pilot for you to light; everything is electronic. You need to get a competent tech out there.Bob Boan
What's the code the board is flashing?0
Looks to me like the make is an ICP furnace. Either an ArcoAire, or maybe a Heil. Hope this helps0
It is an ICP of some sort.0
