fuel cost
HEATON
HEATON Member Posts: 121
What is a good program for fuel cost analysis
  • Zman
    Zman Member Posts: 7,611
    I like the attached spread sheet. It does not rely on a website and allows you to adjust more variables. Natural gas for example is has a lower energy value at altitude you need to be able to change the value.
    Albert Einstein
  • HEATON
    thanks for the input. I still need some formula for the cost of a CFM
    of air at the various ambient temp and temp rise and temp drop at the various rates?? thanks again
  • HEATON
    thanks
    Jamie Hall Member Posts: 27,237
    At normal room temperatures the heat capacity of air is approximately 0.24 BTU/lb F. The density is about .00234 slugs/cuft. Given those two numbers you can easily compute the required heating rate -- in, say, BTUh -- for any delta T (in Fahrenheit) and air flow rate in, say, CFM.
