Hydronic system blowing cold air
a_tebo48
Member Posts: 1
I have a oil fired boiler with and air handler with a hot water coil. The boiler comes on and comes up to temp and shuts off. Both zones circulators are working and water is circulating. I have hot water going into the coil and coming out of the coil but it's still blowing cool air out of the vents.
Three possibilities. Too low a water temperature going in. Too much air flow. Not enough water flow.Br. Jamie, osb
There could be an internal 3 way valve in the AHU. It could simply be bypassing the coil and sending hot water back out.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
