Hydronic system blowing cold air
a_tebo48
a_tebo48 Member Posts: 1
I have a oil fired boiler with and air handler with a hot water coil. The boiler comes on and comes up to temp and shuts off. Both zones circulators are working and water is circulating. I have hot water going into the coil and coming out of the coil but it's still blowing cool air out of the vents.
    Jamie Hall Member Posts: 25,795
    Three possibilities. Too low a water temperature going in. Too much air flow. Not enough water flow.
  • Ironman
    Ironman Member Posts: 7,692
    There could be an internal 3 way valve in the AHU. It could simply be bypassing the coil and sending hot water back out.
    Bob Boan
