Gauge
I found this gauge on a steam boiler (1-pipe) which seemed to be running fine. It shows pressure and vacuum, but no indication of units, i.e. ounces, psi.
If psi, I will want to change the gauge or pressuretrol, but don't want to do so needlessly.
Alan
  • ratio
    ratio Member Posts: 4,176
    Likely 30 psig, & almost certainly 30 in Hg.
    SWEICanucker
    Jamie Hall Member Posts: 26,834
    and you need to keep that gauge, even if it doesn't show anything -- the insurance people (and the building inspector) want to have a gauge with twice the pressure relief valve setting. However, it is no problem to install a nice low pressure gauge -- put it on the same pigtail with the pressuretrol or vapourstat.
  • ChrisJ
    ChrisJ Member Posts: 17,068
    It's currently showing 29 PSIG.
    I doubt he should keep that one. :)
    It's hard to see in the small picture but does it say WC on the left bottom?
  • It says "VAC."
    Chris said, "It's currently showing 29 PSIG." That's the main thing I was concerned about.
    It says "VAC."
    It's busted. But it wouldn't show anything anyway...
  • ChrisJ
    It says "VAC."
    Code says a working 30 PSIG gauge.
    Not a broken one stuck at 29 PSIG even when the boiler is off. :)
    I wonder if you removed that gauge and tried to clean it out if it would work. I bet the internal siphon is plugged with rust and crud.
  • neilc
    neilc Member Posts: 3,116
    was thinking the same thing,
    but how did we get to 29?
    that can't be cummulitive,
    known to beat dead horses
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    These old bourdon tube gauges have a sector and pinion mechanism that can get out of whack for a variety of reasons, but they're very durable and can usually be fixed, if you can get them apart. With mine, the hard part was getting it off the boiler, It's hard to get a wrench behind the gauge, and then there's always fossilized thread sealant to deal with.
