Gauge
Member Posts: 4,022
I found this gauge on a steam boiler (1-pipe) which seemed to be running fine. It shows pressure and vacuum, but no indication of units, i.e. ounces, psi.
If psi, I will want to change the gauge or pressuretrol, but don't want to do so needlessly.
Alan
Alan
and you need to keep that gauge, even if it doesn't show anything -- the insurance people (and the building inspector) want to have a gauge with twice the pressure relief valve setting. However, it is no problem to install a nice low pressure gauge -- put it on the same pigtail with the pressuretrol or vapourstat.Br. Jamie, osb
It's currently showing 29 PSIG.Jamie Hall said:and you need to keep that gauge, even if it doesn't show anything -- the insurance people (and the building inspector) want to have a gauge with twice the pressure relief valve setting. However, it is no problem to install a nice low pressure gauge -- put it on the same pigtail with the pressuretrol or vapourstat.
I doubt he should keep that one.
It's hard to see in the small picture but does it say WC on the left bottom?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
It says "VAC."
Chris said, "It's currently showing 29 PSIG." That's the main thing I was concerned about.
It's busted. But it wouldn't show anything anyway...It says "VAC."
Chris said, "It's currently showing 29 PSIG." That's the main thing I was concerned about.Br. Jamie, osb
Not a broken one stuck at 29 PSIG even when the boiler is off.
I wonder if you removed that gauge and tried to clean it out if it would work. I bet the internal siphon is plugged with rust and crud.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
was thinking the same thing,
but how did we get to 29?
that can't be cummulitive,known to beat dead horses0 -
These old bourdon tube gauges have a sector and pinion mechanism that can get out of whack for a variety of reasons, but they're very durable and can usually be fixed, if you can get them apart. With mine, the hard part was getting it off the boiler, It's hard to get a wrench behind the gauge, and then there's always fossilized thread sealant to deal with.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
