Header Confusion
New England SteamWorks
Member Posts: 1,506
Ran into this boiler that wasn't functioning very well. The two supply mains are each 2-1/2". At least the header piping shows a certain amount of creativity?
newenglandsteamworks.com
This one wasn't going to be easy. To begin with, they put the boiler in the wrong spot. If a decent header was ever going to be built and connected properly to the mains, the boiler was going to have to move. Ugh.
Now what?
newenglandsteamworks.com0 -
Construct the proper header?0
I think @Leon82 has it correct.Leon82 said:Construct the proper header?
But, I'm not doing anything until @Fred weighs in....
I don't know..........I kinda liked the orgasmatron0
I say see if you can raise those risers up so you can put a nice drop header in. I wouldn't mind seeing that Hartford loop raised just a bit also. The bottom of it looks like it's pretty close to the bottom of the boiler. Nothing like a little bit more water in the boiler if there were a leak in the wet return and the LWCO were to fail, but that's just me anticipating a "worse case" scenario. Is there a skim port anywhere on there? On the back side maybe?Paul48 said:I don't know..........I kinda liked the orgasmatron
Thank you Fred. How about something like this?Fred said:I say see if you can raise those risers up so you can put a nice drop header in. I wouldn't mind seeing that Hartford loop raised just a bit also
newenglandsteamworks.com3 -
Nice job!! @RI_SteamWorks ...... 4 inch header??ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Maybe some Big Mouths would be a nice addition?
newenglandsteamworks.com1 -
Most definitely, and with a strainer on it, no less!0
Talk about making a silk purse out of a sows ear...nice job. I like the remnants of the old coal bin next to it. It's like a bridge across time.0
Beautiful job as always @RI_SteamWorks0
Awesome job @RI_SteamWorks.Bob Boan
And how about a vaporstat and low pressure gauge?
Snug as a bug in a rug...
newenglandsteamworks.com5 -
Wow, talk about a job done well! It looks beautiful @RI_SteamWorks0
Looks great! I'm not a pro but have a question on the vapor stat and gauge setup: i don't see a pigtail but see a modified loop with black pipe. This setup removes the need of a pigtail obviously?0
Thank you. And yes, with the added benefit of a larger pipe diameter making a clog less likely.hboogz said:Looks great! I'm not a pro but have a question on the vapor stat and gauge setup: i don't see a pigtail but see a modified loop with black pipe. This setup removes the need of a pigtail obviously?
Awesome. Any special requirements you implement? Close nipples to form the loop? First time I'm seeing that setup, looks great.0
Dang! now thats one sweet looking header replacement. You do some of the nicest pipe work i've seen. Well done!gwgillplumbingandheating.com
great work! can someone share a source for the fiberglass insulation and the plastic wrap that goes around it please? I have a small amount of patchwork to do - thanks0
Man I need to come work with you one of these days, tell me when.Peter Owens
SteamIQ0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
