Microbubble Air Eliminator
Member Posts: 4,624
in Gas Heating
Does anyone make an air eliminator with a union connection like they do for fill valves or mixing valves. It sure would make servicing/replacement a lot easier, no?
The Caleffi hydro seps with microbubble and dirt separator have unions on them, can't think of any others off the top of my head.
Totally agree though, would love unions on them....0 -
Replacing this leaking Vortex would be a snap with a union connection.
quick and simple would b a press version, 1 or 1-1/4". Or a threaded version could be assembled with any union tailpiece, sweat, MIP, or press.
The Caleffi, SpiroVent, and SuperVent can all be disassembled in place and the guts replaced.Bob Boan
Ugh. I hate those ones where you don't have room to do anything. One thing I was always taught was that when you install something, think about how you would replace it. Is there enough room to cut the pipe and solder a coupling? no? well you might be kicking yourself in ten years when you have to replace the thing!!Replacing this leaking Vortex would be a snap with a union connection.
Hope it went well....
2 -
Check out Viega copper press x MIP unions.
79740 1" P x 1" MIP
79745 1 1/4" P x 1 1/4" MIP
79750 1 1/2" P x 1 1/2" MIP
79755 2" P x 2" MIP0 -
Don't, don't, don't try to pull the entire vent out, you'll crush it along with using some very foul language at the same time. That vent is Loc-Tited in.
If its leaking from the top, simply replace the float mechanism and cap from a standard 400 style vent assembly, then discard the leftover body.
Dave HDave Holdorf
Taco, Inc
Agreed Dave0
SPIROVENT VJR,VJS and VJV
Junior Series Air Eliminator
Had one of these pieces of garbage blow off uncontrollably while purging new zone on 10 year old system. Yes, it is installed as per man specs and there is no glycol in system and boiler pressure is normal... Got it to stop by lighting tapping on it and the before our eyes, about 5 min later it blew off uncontrollably again.... Good thing we stayed to watch boiler reach temp and check circulation of new zone, otherwise it would have flooded the basement. I had to cap it off with a 1/2" cap....... it just wouldn't stop. BEWARE IF YOU DONT WANT A LIABILITY INSURANCE INCREASE!!0 -
There was room enough for a union on the left side and we unbolted the pump flange on the right side and replaced it with a Caleffi (sweat connection) air eliminator.
Yes, I've tried removing that vent as well. The Loc-Tite would not yield and I ended up destroying the vent.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
