6 inch drop header coming up
Paul S_3
Paul S_3 Member Posts: 1,294
in a few weeks. i will keep you guys posted.
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
«1
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Let me guess, it's for a power vent IN3? :wink:
    Paul S_3JohnNY
  • Paul S_3
    lol...no weil mclain 680
    347-692-4777
    ASMHVACNYC.COM
  • Danny Scully
    edited July 2016
    Update? Never mind just re-read a few weeks :disappointed:
  • lchmb
    lchmb Member Posts: 2,997
    some reason my arms just started hurting... WOW..
  • EzzyT
    EzzyT Member Posts: 1,379
    Turning those 5' steel pipe wrenches are a work out
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Paul S_3
  • Paul S_3
    I bought (1) 60 inch....and I have a 36 inch chain wrench...they should work? I never turned bigger than 4 inch
    347-692-4777
    ASMHVACNYC.COM
  • EzzyT
    36" chain wrench capacity is 41/2" you'll need another 5' wrench
    201-887-8856
  • EzzyT
    3 strand lamp wick and Permabond will do the job on those 6" nipples and pipe threads
    201-887-8856
  • Paul S_3
    edited July 2016
    the 36 in chain wrench wraps around the fittings with a lot of slack.... seems like itll work....I believe JSTAR used this type of wrench with the 60in...ezzy when you say 3strand lamp wick...you mean the wick that comes in a ball? I was thinking lamp wick,megatape and megaloc.....Ive used that on 3 and 4in...has anybody used Ridgid's compound leverage wrench? looks big and bulky
    347-692-4777
    ASMHVACNYC.COM
  • ChrisJ
    ChrisJ Member Posts: 17,283
    Amatuer question here, please don't take offense.
    But, why would you need lampwick with good cut threads and quality fittings? Shouldn't Megaloc alone work just fine?
  • EzzyT
    It will work with the chain wrenches but you'll have to put a lot of weight into it, yes lamp wick in a ball. Teflon on top of the lamp wick will work too.
    Yes compound pipe wrenches are a bit bulky but there worth having, sometimes you just can't get that extra leverage with a pipe persuader or don't have the room for one that's when the compound pipe wrench comes in handy
    201-887-8856
    SWEI
  • Paul S_3
    edited July 2016
    @ChrisJ I just would like to make sure turning all that pipe and then I have a leak....better safe then sorry....back in march I did a 4 in header I only used megatape and megaloc, no lamp wick worked fine.. I really never use lamp wick on new fittings
    347-692-4777
    ASMHVACNYC.COM
  • Paul S_3
    @EzzyT do you have a compound wrench? do you use it often if you do?
    347-692-4777
    ASMHVACNYC.COM
  • ChrisJ
    On my 2" risers and 3" header I only used Megaloc dope on all new joints, nothing else. Into the block I used Blue Monster tape + Megalock just because I didn't like the feel of the threads. Also tape + dope into the original fittings on the mains.
    The way I go, with the few things I do is if I can thread it together dry a few turns smoothly, I use only dope. If it binds fast, and feels poor I use tape and dope.
    The only thing I've had problems with were female copper adapters which is why I've been using brass couplers + copper male adapters ever since. Never an issue since switching.
    If I have to use nipples or fittings from Home Depot or Lowes I throw them out and find good material.
    Of course, I haven't done a huge amount of threaded joints. Probably what I do in a year a typical contractor does in a day. But it works for me, so far. I only asked because I wanted to know Ezzy's reason for using lamp wick on the larger fittings. I thought perhaps because it's hard to "tighten the hell out of them" like you can with smaller stuff. You never know, I may end up with an EG-35 with a 5 or 6" header one day. :)
  • EzzyT
    Chris the thread depth on 6" are really deep and Teflon tape just doesn't do it
    201-887-8856
    ChrisJPaul S_3
  • EzzyT
    Yes I do and use it not so often but when I need it I have it
    201-887-8856
  • ChrisJ
    I didn't think about the thread depth. Personally I feel PTFE tape works best at sealing, while dope works best at lubricating. So, you're reasoning of the wick because of the deeper threads makes sense in my mind.
  • SWEI
    SWEI Member Posts: 7,348
    The old guys used litharge and glycerine. We have anaerobic threadlockers.
  • Paul S_3
    some progress on 6 inch header.
    347-692-4777
    ASMHVACNYC.COM
  • Paul S_3
    347-692-4777
    ASMHVACNYC.COM
    New England SteamWorksSteve Minnich
  • EzzyT
    Looking good @Paul S
    201-887-8856
    Paul S_3
  • Fred
    Fred Member Posts: 8,542
    WoW! Beautiful!
    Paul S_3
  • EzzyT
    What size boiler is that again?
    201-887-8856
  • Paul S_3
    edited September 2016
    787K weil mclain 680....thanks guys
    347-692-4777
    ASMHVACNYC.COM
  • warno
    warno Member Posts: 229
    Good gerd!!! I really hope the handle on that big wrench is aluminum. Makes me glad I weld everything, takes 10 times longer but my tools are light enough a child could use them.
    Looks good man!
    Paul S_3
  • Dave0176
    Dave0176 Member Posts: 1,178
    Paul show those welders there are still real men that can screw pipe lmaooooo.....
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    Specializing in Steam Heating, Serving the residents of New Jersey
    https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
    https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
    Paul S_3EzzyTCLambSeanBeans
  • Paul S_3
    Lmao
    347-692-4777
    ASMHVACNYC.COM
  • EzzyT
    Hahaha
    201-887-8856
  • warno
    It takes a real man to swing those wrenches. That's for sure! I've had to run my fair share of 1" and 2" pipe threading it together but never 6".
  • Paul S_3
    i personally think the 4 in was harder connecting to the supply mains 9 feet high....6 inch is just really heavy but its a straight run....the 4 inch is tough to line up, up that high.....and big thanks to @EzzyT for all the help and tips
    347-692-4777
    ASMHVACNYC.COM
  • EzzyT
    Those steel 5 footers are a workout lol. No problem @Paul S anytime
    201-887-8856
  • Sailah
    Sailah Member Posts: 826
    Man I got tired just looking at those pictures. I need to go out to the plant and do some 2" steam trap curls...
    Peter Owens
    SteamIQ
    SWEI
  • EzzyT
    Lmao
    201-887-8856
  • Looking very nice indeed. Excellent design, perfect proportions, I see the equalizer already lined up to the return. Bravo! Can't wait for tomorrow's pics.
    newenglandsteamworks.com
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,315
    VERY NICE!!!! That boiler will have a mcuh better chance of having a long life with the movement allowed by those threaded fittings. I don't think I have seen a single big Weil (or for that better most any newer larger cast iron boiler) here in Chicago installed with threaded swing joints, let alone a drop header. Everything is welded right up to the block, often with no swing arms at all. Sometimes we'll see a few flanges on the boiler risers that may allow the block to move but that's it. 14 years for the LGB's and maybe a little longer for the 88's is the typical life we see with all welded piping on multiple riser boilers. Single riser boilers generally last about twice as long or more. It's great to see someone investing in piping it up for decades of life.
  • njtommy
    njtommy Member Posts: 1,105
    Nice work.
    Paul S_3
  • Paul S_3
    what do you guys think so far ? any suggestions to improve installation?
    .....im piping storage tanks soon....i soldered on this job not the usual propress i had the time and have a bunch of sweat fittings .....im still not as good as @Stephen Minnich though....lol...thanks Paul S
    347-692-4777
    ASMHVACNYC.COM
    ChrisJSWEIjonny88Sailah
  • Fred
    Beautiful!
  • EzzyT
    Beautiful as always @Paul S
    201-887-8856
  • Paul S_3
    Thanks @EzzyT .....thanks again for all your help....Ezzy you are one knowledgable individual....i also found a few bottles of steamaster tablets....finally...there not that readily available.....
    347-692-4777
    ASMHVACNYC.COM
    jonny88
