6 inch drop header coming up
Paul S_3
Member Posts: 1,261
in a few weeks. i will keep you guys posted.
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
lol...no weil mclain 680ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Update? Never mind just re-read a few weeks0
some reason my arms just started hurting... WOW..
Turning those 5' steel pipe wrenches are a work out1
I bought (1) 60 inch....and I have a 36 inch chain wrench...they should work? I never turned bigger than 4 inchASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
36" chain wrench capacity is 41/2" you'll need another 5' wrench0
3 strand lamp wick and Permabond will do the job on those 6" nipples and pipe threads0
the 36 in chain wrench wraps around the fittings with a lot of slack.... seems like itll work....I believe JSTAR used this type of wrench with the 60in...ezzy when you say 3strand lamp wick...you mean the wick that comes in a ball? I was thinking lamp wick,megatape and megaloc.....Ive used that on 3 and 4in...has anybody used Ridgid's compound leverage wrench? looks big and bulkyASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Amatuer question here, please don't take offense.
But, why would you need lampwick with good cut threads and quality fittings? Shouldn't Megaloc alone work just fine?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
It will work with the chain wrenches but you'll have to put a lot of weight into it, yes lamp wick in a ball. Teflon on top of the lamp wick will work too.
Yes compound pipe wrenches are a bit bulky but there worth having, sometimes you just can't get that extra leverage with a pipe persuader or don't have the room for one that's when the compound pipe wrench comes in handy1 -
@ChrisJ I just would like to make sure turning all that pipe and then I have a leak....better safe then sorry....back in march I did a 4 in header I only used megatape and megaloc, no lamp wick worked fine.. I really never use lamp wick on new fittingsASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
@EzzyT do you have a compound wrench? do you use it often if you do?ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
On my 2" risers and 3" header I only used Megaloc dope on all new joints, nothing else. Into the block I used Blue Monster tape + Megalock just because I didn't like the feel of the threads. Also tape + dope into the original fittings on the mains.Paul S said:@ChrisJ I just would like to make sure turning all that pipe and then I have a leak....better safe then sorry....back in march I did a 4 in header I only used megatape and megaloc, no lamp wick worked fine.. I really never use lamp wick on new fittings
The way I go, with the few things I do is if I can thread it together dry a few turns smoothly, I use only dope. If it binds fast, and feels poor I use tape and dope.
The only thing I've had problems with were female copper adapters which is why I've been using brass couplers + copper male adapters ever since. Never an issue since switching.
If I have to use nipples or fittings from Home Depot or Lowes I throw them out and find good material.
Of course, I haven't done a huge amount of threaded joints. Probably what I do in a year a typical contractor does in a day. But it works for me, so far. I only asked because I wanted to know Ezzy's reason for using lamp wick on the larger fittings. I thought perhaps because it's hard to "tighten the hell out of them" like you can with smaller stuff. You never know, I may end up with an EG-35 with a 5 or 6" header one day.
Chris the thread depth on 6" are really deep and Teflon tape just doesn't do it2
Yes I do and use it not so often but when I need it I have it0
I didn't think about the thread depth. Personally I feel PTFE tape works best at sealing, while dope works best at lubricating. So, you're reasoning of the wick because of the deeper threads makes sense in my mind.EzzyT said:Chris the thread depth on 6" are really deep and Teflon tape just doesn't do it
The old guys used litharge and glycerine. We have anaerobic threadlockers.0
some progress on 6 inch header.
347-692-4777
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company2 -
787K weil mclain 680....thanks guysASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Paul show those welders there are still real men that can screw pipe lmaooooo.....DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......4 -
LmaoASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
It takes a real man to swing those wrenches. That's for sure! I've had to run my fair share of 1" and 2" pipe threading it together but never 6".0
i personally think the 4 in was harder connecting to the supply mains 9 feet high....6 inch is just really heavy but its a straight run....the 4 inch is tough to line up, up that high.....and big thanks to @EzzyT for all the help and tipsASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Those steel 5 footers are a workout lol. No problem @Paul S anytime0
Looking very nice indeed. Excellent design, perfect proportions, I see the equalizer already lined up to the return. Bravo! Can't wait for tomorrow's pics.New England SteamWorks
newenglandsteamworks.com0 -
VERY NICE!!!! That boiler will have a mcuh better chance of having a long life with the movement allowed by those threaded fittings. I don't think I have seen a single big Weil (or for that better most any newer larger cast iron boiler) here in Chicago installed with threaded swing joints, let alone a drop header. Everything is welded right up to the block, often with no swing arms at all. Sometimes we'll see a few flanges on the boiler risers that may allow the block to move but that's it. 14 years for the LGB's and maybe a little longer for the 88's is the typical life we see with all welded piping on multiple riser boilers. Single riser boilers generally last about twice as long or more. It's great to see someone investing in piping it up for decades of life.To learn more about this professional, click here to visit their ad in Find A Contractor.0
what do you guys think so far ? any suggestions to improve installation?
.....im piping storage tanks soon....i soldered on this job not the usual propress i had the time and have a bunch of sweat fittings .....im still not as good as @Stephen Minnich though....lol...thanks Paul S
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company4 -
Beautiful!0
Thanks @EzzyT .....thanks again for all your help....Ezzy you are one knowledgable individual....i also found a few bottles of steamaster tablets....finally...there not that readily available.....
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
