First day piping the KHN's
Steve Minnich
Member Posts: 2,964
And it's the first time I've ever used this model. I really like it so far; well thought out.
Anyone else been using them?
Yesterday, I had to build a 14' wide and 10' high wall so I'd have a decent place for the near boiler piping. Behind the new wall is a 125 year old stone wall.
Steve Minnich
6
i have 2 jobs going in in mid july....im using this model....i like the minimum firing rate ....i will be using the 0-10v option on the boiler pumps....i used the WHNs i really like them...these KHNs have great turndown ratios for micro zones....i love seeing your work @Stephen MinnichASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
Thanks for the input. The WHN's are awesome. I've installed plenty of those and never had issues, not even with LP. I owe that to Ironman. He gave me some really helpful tips on how to dial in the LP units.
You can't see it but theres a 4" offset in the wall(s) I built so it looks a little funky. There's actually 45*s there but you can't see them in the picture.
We're having a heckuva time pulling the plugs on the radiators. Or, I should say Tim is. I haven't jumped in yet because I've been in the boiler room, but it probably won't be any easier for me.Steve Minnich0 -
i see the 45s ...there right after the tees where the boiler on the right ties into....these rads where used for steam before?....i would just buy the impact wrench and try may save you some time...ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Thanks @Paul S - I'm going to stop and buy one on the way to the job tomorrow.
Yes, steam.Steve Minnich0 -
Good luck....homerun system?ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Yes sir.Steve Minnich0
Nice....I have seen you use Viega Fostapex....my supply house has started carrying it with all the fittings....should i start using it?are you sing Trvs?or zone valves?ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Be very careful on the gas hookup that you don't stress the pipe. If you look at where the assembly ties in to the intake manifold, you will see it is a very weak casting spot. I put in an 085 a couple of weeks ago and could not get it to light. Finally noticed a crack on the intake that was sucking in air. Appears to be from factory(????).
The intake manifold needs to be beefed up where the gas line hooks to it. Apparently, there have been a couple other ones around here do the same thing.
I still have not been able to get back to really watch it much, but so far it is a nice unit.
P.s. The front display needs to have a different "faceplate" on it as part of the display is hidden behind the graphics.
Rick
2 -
@ironman - Great to hear from you, Bob. No PP. Something is stopping from making the jump even though I keep saying I'm going to. Maybe on the next church? That one is 3" pipe.Steve Minnich0
What's that plug for on the iso valve above the circ? Haven't seen that before.Bob Boan
beautiful work @Stephen MinnichASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Looks very nice Stephen!0
Thank you, Harvey!Steve Minnich0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
