My first radius fitting...
Steve Minnich
Member Posts: 2,868
in about 10 years. It's kind of like riding a bike. A little wobbly at first but it comes back to you.
I had sold all my fabricating equipment years ago but in the last 2 months I've been getting killed on having someone else make custom made fittings for various jobs. So, I reinvested to a degree. It's the one thing I miss about that side of the industry, making fittings.
Steve Minnich
1
nice job @Stephen MinnichASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Thank you @PaulS. I had someone make 2 simple y-branch fittings for me last week. After I got the bill, I knew it was time to get an Easy Edger and a Slip Roll. The Slip Roll is the oldest one I've ever seen but it works fine.
Steve Minnich1 -
Cool .
I worked in a shop many years ago. The old man that I worked under used to say " whoever named this thing " Easy - Edger " never had to ( bleeping ) use it ".
I once launched " The Radius Revolution " in the shop that I worked. I made every square heel / throat that was listed in a curved fashion. This lasted for a few days before it was squashed by management , lol. I miss having a shop to make stuff sometimes.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Yea, it's fun and challenging. I use to have an edger on top of a Lockformer machine and that's a piece of cake. Doing it manually is an art.Steve Minnich0
I worked in a factor for over 30 years, even when I was in management you'd find me down in the machine shop building something before work or during lunch (ruined a few ties that way). Nothing fancy, just whatever I needed to perform a test or to fix something from home.
3PSI gauge0 -
We make most of our tin as well. We just got a new shear, as the old one lost to much babbitt, & it's getting hard to find dinosaur hide to make new drive belts... The new one's Japanese IIRC.0
Nice work but a poor design .
That depends. Sometimes an imperfect design is the best case answer to what field conditions dictate. But in this case, the fitting will likely never be used. It's 6" x 6" and I made it just to get back in the groove.Steve Minnich0
