Brazing/soldering copper to steel or brass
whiteke12
Member Posts: 13
I have been using Mapp/Oxygen for this and brass rod with powder flux. Half the time it looks beautiful, but the other half looks like hell.
With the current setup of Mapp/Oxygen, is there any universal rod with flux that would work with both. Safety Silv 45 is what I was told or 15? Working on refrigeration lines that are 1/4". Or any suggestions?
I use 45% with flux & Turbo
Search this site theirs several videos0 -
JW Harris website is another good source. I've been trying copper to stainless brazing and found the flux coated rod works best.Bob "hot rod" Rohr
What is the flux coated rod name? Appreciate all the responses.0
Is there a universal rod for copper to steel and brass?0
Safety-sil 45 is the Harris brand of brass or copper to steel flux coated rod.
Regular brass brazing rod with powder flux works fine also. I have used copper wire, like #12 Romex wire to braze copper and steel
Use a fine tip oxy acetylene torch for good flame and temperature control when brazing. A soldering torch is to wide of a flame and not hot enough for brazing all but the smallest of tube or piecesBob "hot rod" Rohr
Google your question, there is a lot of information out there. Copper gives off fumes when welding it that is not good for you. I did not see that mentioned though when I googled it. Lots of information on TIG welding copper. There should be some on oxygen/acetylene welding copper.0
The joint must be clean clean clean. Then use the thin roll of 45% and use oxy / act. You also need a paste flux. You need around 1400*f for a good joint, it will flow like 50/50 when cleaned and fluxed.0
I started practicing again....the cleaner I get, the better it goes...and the right heat. I think I have a better understanding today. Clean, clean, clean like you said is number one, then heat.
Last three went well with rods I have but still might pick up flux coated rods...I do not need an external paste then correct?0 -
With coated rod no but the coating gets damp sometimes so i still use paste0
Ok perfect. Thanks for all the help. Think I got straightens out.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
