Brazing/soldering copper to steel or brass
whiteke12
whiteke12 Member Posts: 13
I have been using Mapp/Oxygen for this and brass rod with powder flux. Half the time it looks beautiful, but the other half looks like hell.
With the current setup of Mapp/Oxygen, is there any universal rod with flux that would work with both. Safety Silv 45 is what I was told or 15? Working on refrigeration lines that are 1/4". Or any suggestions?
    pecmsg Member Posts: 6,781
    I use 45% with flux & Turbo
    Search this site theirs several videos
    hot_rod Member Posts: 26,606
    JW Harris website is another good source. I've been trying copper to stainless brazing and found the flux coated rod works best.
  • whiteke12
    What is the flux coated rod name? Appreciate all the responses.
  • whiteke12
    Is there a universal rod for copper to steel and brass?
    Safety-sil 45 is the Harris brand of brass or copper to steel flux coated rod.
    Regular brass brazing rod with powder flux works fine also. I have used copper wire, like #12 Romex wire to braze copper and steel
    Use a fine tip oxy acetylene torch for good flame and temperature control when brazing. A soldering torch is to wide of a flame and not hot enough for brazing all but the smallest of tube or pieces
  • cutter
    cutter Member Posts: 312
    Google your question, there is a lot of information out there. Copper gives off fumes when welding it that is not good for you. I did not see that mentioned though when I googled it. Lots of information on TIG welding copper. There should be some on oxygen/acetylene welding copper.
  • unclejohn
    unclejohn Member Posts: 1,833
    The joint must be clean clean clean. Then use the thin roll of 45% and use oxy / act. You also need a paste flux. You need around 1400*f for a good joint, it will flow like 50/50 when cleaned and fluxed.
  • whiteke12
    I started practicing again....the cleaner I get, the better it goes...and the right heat. I think I have a better understanding today. Clean, clean, clean like you said is number one, then heat.
    Last three went well with rods I have but still might pick up flux coated rods...I do not need an external paste then correct?
    With coated rod no but the coating gets damp sometimes so i still use paste
  • whiteke12
    Ok perfect. Thanks for all the help. Think I got straightens out.
